bigbadchev84
what gives? the 350 in my blazer is having some issues, this thing used to run flawlessly. I am currently without a choke, it is wired open. I let it warm up for at least 15min before driving anywhere in this cold weather. I went to leave work today and it started backfiring through the exaust really bad and sputtering, I pushed in the clutch and tried to clean it out hitting the gas pedal and it just sputtered some more, then cleaned out. shortly after it did it again and I floored it, it acted normal to about 3500rpm then started bucking and sputtering again until i let out at the same time my fuelgauge and tach were bouncing all over the place, ran fine after that. unless i get into it, it does the same thing. My tach will also intermitinly jump a couple hundred rpm
I am running a quadrajet
Its got new:-less than 200miles
fuel pump
carb filter
wires
cap
rotor
ac delco plugs
fuel pump
carb filter
wires
cap
rotor
ac delco plugs
