I'd just fix the choke or convert it to a hand choke cable--it might start OK in your warm garage,but what about after you go somewhere and park it outside at zero degrees?--you'll be like me,the guy who's diesel started fine while its block heater was plugged in at home--but are bummin when its time to come home from work where there's no place to plug it in and now it refuses to fire up!--and your forced to risk using starting fluid...
I have wired chokes open on many of my vehicles in the warm weather and noticed a slight gain in gas mileage,but the poor running,bogging,stalling and other woes I had to endure the first few miles got to be discouraging and more than once almost caused an accident,when they would stall out when pulling away from an intersection,etc...I prefer hand chokes,but remembering to fully OPEN the choke when you have one is hard to do,many times I caught myself driving around with the choke better than halfway closed--didn't do my rings any justice,and the oil gets diluted with gas,etc..one truck I rigged up an idicator lamp to remind me the choke was still "on" ,that helped a lot..
