urbex
My new-to-me 6.5TD definately takes more cranking when hot than cold, but as this is my first GM diesel, I don't know what's "normal" and what isn't...
Truck is a '96 K2500. Fires up no problem when cold - turn key to on, wait for WTS light to go out, and it fires right up, usually in less than a second of cranking. Drive it around for an hour, stop at a gas station just long enough to grab a soda and back out, truck is sitting for less than 5 minutes, might take 2 or 3 seconds of cranking, but always fires right back up.
But same scenario, but let the truck sit for an hour, and now it takes 10-15 seconds of cranking to fire up. Zero signs of life other than cranking. No diesel smell/smoke, no sputtering, just cranking. Then it suddenly lights off, and runs great.
Let the truck sit for 3 or 4 hours, and it's right back to firing right up again.
I recently put two brand new batteries in it, as I found that it only had about 30 seconds of cranking in it before the batteries went flat. They definitely made an improvement in cranking speed, and decreased hot restart cranking time, but it still seems abnormally long...but again, I don't know what's "normal" or not on these trucks either.
I haven't noticed any running issues at all while it's running, has never stalled out on me. PMD has been relocated to the driver's side fender between battery and master cylinder (I'm planning on relocating it again, outside the engine bay). I put in a new electric lift pump and fuel filter under hood a few weeks ago (lift pump was intermittent when I bought the truck) Pouring water over the IP and PMD when hot doesn't make a bit of difference in cranking time. After putting new batteries in, it hasn't failed to restart, just seems to take longer than I think it should.
, and the only other frame of reference I have is my 7.3 turbo. It's like the exact opposite of the 6.5 - a bunch of cranking when cold to light off, but that sucker will light off almost faster than I can turn the key when hot.
But everything about that truck is bigger and heavier duty than the Chevys, and it's what I normally use for heavy hauling/towing. On the other hand, I HATE the Ford interiors, and that truck is anything but comfortable to drive long distances. My '59 International 2.5 ton truck is more comfortable than that Ford, and I could easily do a 1000 mile day in the Chevy.
. I wrote that after a long hot day, I was a little
