IV Quattro
Registered Member
Recently my Blazer has been throwing an EST Low voltage code, I've got a new ignition coil, I pulled the distributer cap and looked at the contacts and they looked clean, my spark plug wires run with some distance away from each other and are parallel, the truck will run but when the check engine light is on it falls on its face a little bit. But the light alternates with my 4wd light and then everything works fine, where is the ground for the instrument cluster and what am I still missing?
