what is needed to mount a big block rad
I just did this 2 nights ago, I pulled the OE 3 row out of my 91 crew cab and put a 4 row rad in. My 3 row had 2 small brackets hold the top of the rad, the 4 row has one long plate that runs the length of the rad. The 4 rubber mounts are different, but my hoses all worked fine.
The only problem I had was my fan shroud. The original one wouldn't readily bolt up so I will either have to modify it or find another. Until then I'm driving without a shroud and (ironically) it runs hotter now than ever before. /forums/images/graemlins/rolleyes.gif
I dont have the part # for the 4 rubber mounts, but I do have them for the shroud & upper mount if you like.
[ QUOTE ]
Who's part numbers are they? Where would such parts need to be purchased?
[/ QUOTE ]
The part #'s are GM & you can order them online or buy they at the dealer.
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]
some dealer parts dept ppl are retarded and dont know how to look up parts and will say that the brackets are all the same 5 through 30 series, talk to a different parts counter person if the one you are talking to says the same thing, the above happened to me in this 15k population town with only one GM dealer
I did this on my 91 quite some time ago. The GM part numbers are.....
upper metal bracket - p/n 14018600
rubber pads (need 4) - p/n 6264100
shroud - p/n 14021289
It all bolts right up.
And I got my 4 core at AutoZone for 170 bux I think P/N 433730.
That P/N isn't coming up on AutoZone.com /forums/images/graemlins/confused.gif
What app would I ask for to get that 4-core rad?
Try looking up a 1987 Chevy Suburban 3/4 ton 2WD with the 454 TBI and the automatic. I just checked and it comes up with the 433730 part number ($159.99). Like Bigburb, I also used the Autozone rad. GDI 4 core. Works great!
[ QUOTE ]
what is needed to mount a big block rad in to a 89 front end /forums/images/graemlins/confused.gif i think it is extra thick ?
[/ QUOTE ]
Go to a good radiator shop, that sells Modine radiators. They can do cross reference on it, for one that is a bolt right in fit, for $167.00 That is what I did, for my '87.
OK cool, it's either my laptop has a dislike of AutoZone.com, or a keyboard actuator error.
I'm betting on the latter... /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif
