Kain
3/4 ton status
just curios if there are any advantages to a hawse over a roller
The thing that scares me about the rollers is ive seen one let go. Granted it was a sideways pull but it was like a bullet when it took off.
But rollers look bitchin.
And mine came with a roller, so . . .that's what got bolted on. lol.
thats one thing i was going to do is get grade 8 hardware if it does not come with it
ya i have a warn steel hawse coming its steel part # WARN 73850 it says its steel so I will see if i like itHawse, cause the roller stuck out far enough to hit everything on the old bumper. Had lots of abuse, which would lead to failure. Hawse is normally a rope thing but is ok if you run a steel hawse for cable. Aluminum might be too soft and chew up.
