What is the going price for 73-87 ralley rims?
I sold a set for $350 with good tires. I have no 6 lug trucks so they just had to go away.
I use to buy half tons for $100 - $200, and pile up the rally wheels.
Depends on the condition, and if they have rings and center caps (and if they do, their condition).
Martin
Here in WA state, $150-600 depending on condition and if they include trim rings, center caps and/or tires.
No, they are narrower. Except for the M1009 wheels. Those were 15x8 steelies.
What are the stock sizes for each of these?
73-87 standard steel (non ralley) 4x4 - 15x8
73-87 standard steel (non ralley) non 4x4 - ?
73-87 ralley 4x4 - ?
m1009 4x4 -?
I should also mention, 15x7 rally wheels are also out there from G10/G20 vans.
Rally wheels were originally available in either 15"x7" or 15"x8". In the later years they were only available in 15"x8".
The base wheel was most commonly available in 15"x6", but you could get them in 15"x8" if you ordered the correct tire. You could also get 16" or 16.5" wheels on a half ton the first few years.
Martin
From 1975 Blazer.
Close up.
The Rally wheel was originally available in 15”x7” or 15”x8”, same RPO (N67) either way. It just depended on which tire size was ordered.
Martin
From 1975 pickup.
You could get 15”x8” base steel wheels if you ordered a wide “off road” tire.
Martin
