What is the one job.....
Hmm,I always thought it was actual Whale Sperm used for that lube..:blush:
I often pondered--how did they jerk the whale off, to get the sperm into those small bottles..:thinking:...:shocked:..
No typo, I never gave it much thought but people in the business commonly refer to it as "whale sperm".
NO, NO, NO, Dear God NO!
I know it was a typo, but the additive was Sperm Whale Oil, NOT what you said!
Sperm whales have huge reservoirs of oil in their heads that they use as echo chambers for echolocation, and it has amazing properties. I used to have a small jar of it that my father got when he was in the air force during the war.
The military had drums and drums of the stuff as a rust preventive for guns going overseas.
Great stuff, but smelly.
J I always thought that sperm whale oil was made from boiling down the fat from the sperm whale. Then I watched the movie "in the heart of the sea"
Rivet removal on the frame since I don't have an air chisel or a torch... I use a variable speed drill, cobalt or titanium bits, a cold chisel sometimes, a huge punch and a 3 lb. sledge.
I also hate removing the old rubber bushings and the steel sleeves in leaf springs when swapping over to poly bushings.
I guess D60 inner axle seals will be next in my list of hates from reading the feedback on this thread... going though the 60 here soon.
@handloader90
You should be using a cut off wheel, large steel chisel and BFH. Make a few cuts through the head of the rivet with a cut off wheel. Then take the chisel and hammer and whack it off.
Or use a plasma.
I've told here before how my co-worker at the junkyard used an all steel camping hatchet he found in the trunk of a junked car,to litteraly chop off cab mounts,and engine mount brackets on frames,or riveted crossmembers..
--when a customer wanted one and they were not able to remove it themselves--we had to do it manually,because the yard was located in a field surrounded by large pine trees,needles,etc,the place would have gone up like a bonfire if we used the torches or a grinder to remove rivets,and many of the vehicles couldn't be moved ,so it was either wait for a rainy day to torch the brackets off,or do it manually somehow..
One day we tried torching some frame brackets off,I held a old fire extinguisher we had you filled with water,and pressurized with an air hose..it was a dry summer day and it was a miracle we were able to put the blaze out we started with about 5 gallons of water,and our shoes,stomping around like crazy..if the wind had picked up the place would have burnt to the ground..:eek:..
The boss freaked when he saw the burnt grass the next day..
"No more using torches when its dry out--how many times have I told you that "?..:shame:..
This meant hours of agony drilling and chiseling,bashed knuckles,and we tried a sawsall but that damaged the brackets often,or we trashed a lot of blades when they would jam and fold up..
Then one day after the co-worker found that hatchet,he decided to try putting the blade at the joint where the riveted bracket met the frame,and whaled on the other end of the hatchet with a 5 lb. hammer,and to our surprise,it took only 3 or 4 good smacks to wedge the hatchet in between and the rivets popped,sheared in two much easier and faster than any other method like cold chisels..also the blade held up pretty darn good considering the abuse..and there was minimal damage to the bracket,a few whacks with the hammer flattened out any bends the blade made..
Yeas,it was rather risky bussiness,but we wore goggles and heavy welding gloves,and our only injuries were if we missed when we went to hit the hatchet..it was fun watching a customer's eyes when we'd say "OK,stand back and shield your eyes"--then proceed to remove the frame brackets with that method...they were like :eek:..
To our surprise that hatchet never shattered--it did get some deep divots in the blade,but we'd just put a keen edge on it with the grinder before each use..
I hate doing leaf spring u-bolts and shackle bolts too,I usually do not waste time and effort trying to save them,its much faster and easier to use a sawsall or cut off wheel to slice the U-bolts, and shackle bolts in between the bushing and hanger and pry the spring out of the hanger,then light the rubber in the bushings on fire with the torch and let it burn awhile,then the bolt,sleeve and bushing can be shoved out,leaving only the thin steel outer shell in the spring eye,which usually comes out easy--a quick slice with the torch or saw blade and it'll curl inward and fall out..
Usually you have to replace old u-bolts and spring bolts anyway..the sucky thing is trying to find 9/16" gade 5 or 8 bolts the right length around here--90% of hardware stores skip 9/16,they only stock 1/2" or 5/8" bolts..last time I needed bolts for leaf springs I had to go for a 30 mile round trip ride to find 4 of them--also had to hunt for a spring shop that had,or could make u-bolts while you waited..
@handloader90
Or use a plasma.
I use my angle grinder or my die grinder and do the cuts in the head thing whenever possible but taking out the rivets in say the front spring hanger there isn't enought room in there for a 4.5" wheel or the 3" wheel on my die grinder... I think I've tried to stick my dremel in there too but that things a pussy.
I hate the warn snap rings in the D60 hubs. I can never get them in without a fight.
This weekends fun/hate.... Broken bolts. The resulting tantrum cost me a 15mm Snap On socket that's now MIA. :doah:
You can get a grinder on every one, some from the inside of the frame.
I hate aligning the front doors. You about have to remove the whole dash to get that one bolt on the upper hinge. Plus you're always at risk of chipping the paint off the door and fender edges sneaking tools in there. Don't forget you need a hoist or cherry picker and it takes at least 5 iterations on each side.
