garydan
I dropped the 10 bolt axle out of the blazer this weekend and bolted in the 14-bolt. I decided to just cut off the emergency brake lines and the brake "drop-line" from the axle. I'm not going to reuse either.
What is the trick to disconnecting the fittings for the emergency brake line where it attaches to the frame?
And how do you disconnect the brake line so I can reattach an extended line I'm getting from ORD?
(Sorry if this is a dumb question but the attachments weren't simple nuts/bolts.. and I'm a simple man
UPDATE:
As you can see from the pics below, I failed miserably. I couldn't get it loose no matter what I used... flare nut wrench, Vise-Grips, PB-Blaster... nothing help. So I basically just snapped it. Right now I'm thinking about having it towed to get the rest of the lines connected at a shop somewhere.
Rounded off and snapped
And now I have this:
I guess I can just replace the line from this fitting back right? The fitting is inside the frame rail.
The problem is that its bracketed in with the fuel lines all the way back, looks like a major PIA:
Well I have everything else done with the 14-bolt FF install w/Disc brakes. I never thought this damn brake line would be the worst part of it all
ORD long brake line kit... not secured yet.
Thanks,
-Gary
)UPDATE:
Thanks,
-Gary
