What is this axle?
POWERMAD
Oregon
Hey all
Today I was in the boonies on a service call.
This axle is outside next to a barn.
It is an 8 lug full floating design. it has a third member(drop out) and a removeable rear cover. And a torque arm on the right tube.
What is this? I have never seen one of these.
It is a rear axle.
See ya
my truck's not dirty, it's earth tone paint
Need more information to answer that. Or a pic. What shape was the diff cover? Do you know what it was in?
'78 Chevy 1 ton Stepside RockCrawler
468 BB, SM465, NP205
D60 front, GM 14Bolt rear w/ Detroit
Sounds a bit like a old Eaton from 60's very early 70's but really ahve toi look at it. Might even be a 1.5 ton axle. Did it have a big like big 14 bolt sized pumpkin?
Diging it in the dirt with my K5's
Grim-Reaper
<A target="_blank" HREF=http://grimsk5s.coloradok5.com/>http://grimsk5s.coloradok5.com/</A>
If it's a real big round cover with 10 bolts holding it on, it is most likely the Eaton. Used in 3/4 and 1 ton GM trucks from the 40s through about 1970 or so.
Tim
70 Blazer CST 4X4 350 SM465 NP205
87 Burb 4X4 350
01 GMC 2500HD 4X4 Duramax/Allison
I agree with the others that it is an Eaton.... I called my local rearend place and they said they can only get bearings for those and the third member.. Other than that, they said they cant find anyone who carries the parts for them.
<font color=green><A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A></font color=green>
The pumpkin is big like a 14ff. the cover is round and has about 10 bolts holding it on.
If parts were available, I would probebly go back out and try to get it.
Thanx.
See ya
There is a company that is making gears for those Eaton rear ends again. I think Randy's Ring and Pinion sells them. Some of them had factory installed Detroit Lockers, although the Detroit is no longer available new.
Tim
87 Burb 4X4 350
Does this thing look like a Ford 9-inch on steroids with a removable, circular rear cover?? My @$$hole neighbor occasionally has an early El Camino on a 4x4 frame (with 44's) in his driveway, and that sounds like the rearend this thing has under it.
Semper Maintenance!
Hey
That is the best desciption I have heard yet.
A 9" ford on steroids.
I wish I had of taken my camera with me.
I think I'm gonna take some cash out and go back out there Saturday.
See ya
