aaldape
Registered Member
So I'm in the process of fixing some of the little things on my 1988 suburban, and cannot identify a specific part that I was hoping to get some help with.
The piece is located behind the dash, on the right side of the steering column. It is a black plastic cylinder with threads along the entirety of the exterior. It is connected with a sort of barbed port to a rubber hose that I can't seem to follow far enough to ID. Inside the black plastic piece is a white plunger/actuator that is spring loaded. When the plunger is depressed, the barbed port closes and no air can pass through, and when the plunger is in it's "natural state," air flows through the port freely.
It appears like it should be mounted in some sort of threaded insert, but I really just don't know WTF it is... Any help is greatly appreciated...
Here's the beast, just for fun
