what is "zero rate"?
francis
kemp, texas
what is zero rateing :confused: it sound like everyone means moving the axle foward. but how is it done and why is it called "zero rate"
It is called a zero rate for this reason. Since the zero rate is bolted to the spring pack with the centering pin it is technically considered a spring and can legally be used in a front axle. But since it has no spring rate to the springpack it's called a "zero rate spring".
