4X4HIGH said:Definately a 14FF and a 3/4 ton 10 bolt with factory drive slugs.
JEBSR said:Not saying your wrong, but my neighbors truck came with a 10 bolt with factory drive flanges. It had a 350/350/203 combo. I am not positive but I believe it was a 77 model.
sandawgk5 said:Don't Dana 44s have the tierod on top vice the bottom like the picture?
Dik
Nope. 10bolts came with slugs. I have a 3/4 ton 10b on the bed of a truck right now with slugs.Chevy305 said:thats gotta be a 3/4 ton D44 because the 10bolt never came with drive flanges and notice the rotor how its slotted.
thatK30guy said:Nope. 10bolts came with slugs. I have a 3/4 ton 10b on the bed of a truck right now with slugs.
10b's started in '77 and most trucks in '77, '78 and '79 ran 203's in automatics which translates to drive slugs. '80 used ALL 205's and had lockouts.
And what of the slotted rotor? Normal 3/4 ton rotor. Nothing special there.
This one shown above is not a Dana. Its a Corporate.Chevy305 said:If its a Dana axel then it'll have specific markings in the pumpkin. Look straight at the cover and look at each corner of the casting if you see any numbers it "should" be a Dana. Also look on the axel tube itself if it has any numbers punched into it to the right of the pumpkin then its a Dana.
