What makes a cam EFI friendly?
91GMCSuburban
San Antonio, TX
What determines the compatability of a cam to work with EFI?
Can chip reprogramming allow for any cam to be used?
I'm trying to pick the best cam for my app, but I can't figure out if I am restricted to certain cams.
Lope separation plays a big part in how well a cam will work with EFI...112* is about as low a number as you want to have.
Comp Cams, Crane and ???? all have hotlines available where peopel help you decide what is the best cam for your app. Maybe even try Summit Racing or Jegs!
GM TBI EFI is very sensitive to the vacuum the engine makes. The bigger (i.e. longer duration and more lift) cam you have, the less the TBI likes it because it does weird stuff when the vacuum signal is messed up. I think MPFI takes to big cams much better, but someone probably know way more about this than me.
afaik less duration would be needed with EFI due to improved fuel mixture in EFI systems due to injection rather than carb jets
Yeah, somewhere in there I believe. You don't really want to go to much more than that on a truck motor anyway. You can do whatever you want but the more you go over 215 the more the TBI is going to dislike it.
These are the guidlines that AFI uses. Remember these are only guidlines but close. Bigger engines a little more etc...
Maximum duration of 214o intake duration @ .050" and 224o exhaust duration @ .050" . Most cams will give recomendations for like a TBI.
This is only for Speed/Density systems.
the closer you stay to 200* duration the easier it will be for the TBI to deal with it. check out this motor
http://www.high-performance-engines.com/spc1.html
it says the cam specs are 194 intake 204 exh. .398 lift intake,.420 lift exhaust
and its making 310 hp and 410 tq.
personally i wouldnt go with anything above 210 degrees
