What manual trannys work behind a Cadillac 500?
OffRoad
New Brunswick, Canada
nv4500, T56?
i can't stop thinking about cadillac's but i don't want to run a T400.
it'd be going in a 2wd 1/2 ton. (not now, but sometime in the future, ok i'm bench racing, whatever.)
No manuals were ever put behind caddy's. The crank has to be drilled.
ok, what's involved with that?
what transmissions could i use that would hold up to the power?
should i just run a turbo400?
TH400 will be easier. I actually have an empty BOPC TH400 case sitting around.
I know you can make an SM465 work. Kert at DIY4X did. Because of that I would assume that an SM420 or NP435 would work as well.
Don't know about an NV4500, but I would guess you could do that as well.
any of the chevy manuals can be made to work. You have to drill the crank and install a pilot bushing. Very simple task. I did mine with the motor in the rig. It DOES NOT have to be done in a machine shop. Hand drill and a good sharp drill bit.
Adaptor plate is required between the trans and block. Some say there is a bellhousing from a pontiac that will work on the engine side but never found any information on the other side that bolts to the tranny and never found a pontiac bellhousing to look at.
Drilling the drank is ridiculously easy. I drilled mine with the engine assembled hanging from a chain hoist. I drilled a pilot hole 3/4 deep and 3/8ths in diameter in the center dimple in the crank. Then I drilled it out to a 5/8ths diameter hole to the same depth. Took me about 10 minutes to do and I borrowed the drill bit from a buddy. I drilled mine to make the engine fit on a dyno.
George
