what mod did you install ?
sweetk30
Back to play nice .
in the back of your brain
this post is for posting up ------ what mod did you install on your rig that you did not think you would use as much as you actually do use ?
my self i did not think my basic work truck with 3" lift and skinny 33" tires would need a doubler tripple stick combo . but i use the hell out of it already as a work truck backing up trailers so easy and other low speed stuff . its so nice to have control with out working the gas and brake .
thanks OFFROAD DESIGN :saweet::saweet:
Anymore if I don't think Im gonna use it then I don't install it lol. But my yukon, I plan on SAS'n it. I don't need to, it already has a 4" lift on it. But I have 95% of the parts so why not? The wheeling I do and for whats around, the IFS will prolly be fine. But anybody can do an IFS lift....
My Doubler.
I had 5.13's and a 4spd in my last build so low range with granny always felt strong and well controlled. I put a Doubler in the Blazer because all crawlers need an underdrive, right? I didn't think it would make much difference but boy was I wrong! Wheeling with that additional reduction is crazy different, I found myself wanting to use it the entire trip.
Rear winch. Just been a little mile marker 4500 lb unit that was delivered by accident from Summit racing years ago. Have used it on a few different vehicles for recovery but mostly been used for loading stuff on trailers and lifting things. Once the wrecker bed is operational it's rear winches will take over this stuff.
