What PSI do you run on your k5 tires?
Have you ever heard of the paint contact patch method?
essentially paint the tread white with spray paint and drive it (mostly straight)
The paint wears off at the contact patch, depending on inflation
Typically this shows up in the recommended operating range for your psi if the tires are the correct load range and correct wheel width
the 315/70/17s on my k10 are at 42psi
18x39.5 Boggers on 11” wide wheels, I run them at 22 psi. I could probably go down to 18~20 psi but as is the tires feel pretty sloppy on the road at 45-50 mph in curves, etc.
35 psi for street use. 25 psi off road. Also depends on load rating truck tires come in C, D, E. For a K5 I would prefer C rated tires
old truck way back . k10 long bed . sbc iron head / th350-205 / 9" total lift on 38x12.50x16.5 tsl bias ply . 25psi was sweet spot for ride and handling .
as said tire chalk test or paint . and you can dial in the psi any specific combo needs .
Never heard of this. What are you looking for with this method? That the tire tread pattern is fully on the contact patch?
If it’s over inflated, you will wear the paint off the center first, faster
Under will wear the edges first
What load range and tire are you using?
For a 235-75-15 tire what would be a good starting point for tire PSI?
You're running tiny 29" tires which are probably close to the factory door sticker, while asking a group of mostly modified rigs what they run, while as we've already covered, only your axle weights and tires apply.
I've got front and rear axle weights for the crew cab so I do the math based on the max load and psi listed on the tire. It works out to the mid to high 20's. Then I add about 4 psi.
I kind of cross check this with a similar method to what @Bent77 mentioned. I've noticed the tires pick up the fine dust off the shop floor and I can see how far across the tread the dust goes. I like to see it about 90% or so.
