What rear diff is in my truck?
Without any more information than you've given, it's impossible to tell.
Check your RPO code list on the glovebox sticker. Look for these codes in the list.
G80 is a Gov-Loc rear.
[SIZE=+1]G44 : AXLE REAR 3.07 RATIO[/SIZE]
[SIZE=+1]G72 : AXLE REAR, 2.14 RATIO[/SIZE]
[SIZE=+1]G75 : AXLE REAR, 3.62 RATIO[/SIZE]
[SIZE=+1]G80 : AXLE POSITRACTION, LIMITED SLIP[/SIZE]
[SIZE=+1]G87 : RING GEAR, 8.50 INCH[/SIZE]
[SIZE=+1]G89 : RING GEAR, 7.50 INCH[/SIZE]
[SIZE=+1]G92 : AXLE REAR RATIO, PERFORMANCE[/SIZE]
[SIZE=+1]G9S : AXLE REAR RATIO, ECONOMY[/SIZE]
[SIZE=+1]GH0 : AXLE REAR, 3.54 RATIO[/SIZE]
[SIZE=+1]GH2 : AXLE REAR, 2.29 RATIO[/SIZE]
[SIZE=+1]GH3 : AXLE REAR, 2.77 RATIO[/SIZE]
[SIZE=+1]GH4 : AXLE REAR, 2.92 RATIO[/SIZE]
[SIZE=+1]GK9 : AXLE REAR, 4.63 RATIO[/SIZE]
[SIZE=+1]GL3 : AXLE REAR, 6.17 RATIO[/SIZE]
[SIZE=+1]GM1 : AXLE REAR, 2.59 RATIO[/SIZE]
[SIZE=+1]GM3 : AXLE REAR, 3.45 RATIO[/SIZE]
[SIZE=+1]GM8 : AXLE REAR, 2.56 RATIO[/SIZE]
[SIZE=+1]GQ1 : AXLE, STD RATIO[/SIZE]
[SIZE=+1]GS4 : AXLE REAR, 3.70 RATIO[/SIZE]
[SIZE=+1]GT4 : AXLE REAR, 3.73 RATIO[/SIZE]
[SIZE=+1]GT5 : AXLE REAR, 4.10 RATIO[/SIZE]
[SIZE=+1]GT7 : AXLE REAR, 3.33 RATIO[/SIZE]
[SIZE=+1]GT8 : AXLE REAR, 4.10 RATIO[/SIZE]
[SIZE=+1]GTY : AXLE, WIDE TRACK[/SIZE]
[SIZE=+1]GU1 : AXLE REAR, 2.41 RATIO[/SIZE]
[SIZE=+1]GU2 : AXLE REAR, 2.73 RATIO[/SIZE]
[SIZE=+1]GU4 : AXLE REAR, 3.08 RATIO[/SIZE]
[SIZE=+1]GU5 : AXLE REAR, 3.23 RATIO[/SIZE]
[SIZE=+1]GU6 : AXLE REAR, 3.42 RATIO[/SIZE]
[SIZE=+1]GV2 : AXLE REAR, 5.83 RATIO[/SIZE]
[SIZE=+1]GV4 : AXLE REAR, 3.36 RATIO[/SIZE]
[SIZE=+1]GV8 : AXLE REAR, 2.72 RATIO[/SIZE]
[SIZE=+1]GW4 : AXLE REAR, 3.31 RATIO[/SIZE]
[SIZE=+1]GW6 : AXLE REAR, 3.27 RATIO[/SIZE] [SIZE=+1]GW9 : AXLE REAR, 2.93 RATIO[/SIZE]
[SIZE=+1]HC4 : AXLE REAR, 4.56 RATIO[/SIZE]
