What size brake line to go with???
fishinnutt
Littleton CO
I am redoing all the brake lines in my 71 Blazer and I see the line comes in two common sizes 3/16 and 1/4. I am not sure which one to use or rather which one is right to use in a rock crawler application. If there is some critical info missing and I am sure there is, let me know and I will fill in the details.
If memory serves me correctly, 1/4 in is only used from the MC to the rear frame because that line feeds both rear wheels. 3/16" is all that is used for an individual wheel.
The front calipers take more volume though, so they might use 1/4"...you know it's been so long since ive fiddled with the hard lines I can't remember. I do know the rears are 1/4" until it drops to the axle, and then it's 3/16" after the T going to each wheel.
m/c to prop valve 1/4 (both lines)
prop valve to rear hose 1/4
rear hose to wheel cyl 3/16 (both lines)
prop valve to each front brake hose 3/16 (both lines)
Well, that's an A/M prop valve. You can build it with whatever size lines you want to.
IIRC from my schooling... Using one 3/16 line to feed (2) 3/16 lines will give you a soft pedal. It doesn't change the output pressure but increases fluid flow (or something to that effect). So, when building your hydraulic system, a good rule of thumb will be to feed with 1/4 and split with 3/16. Does that make sense?
Yes that makes perfect sense. So the above prop valve I linked can be fed with 1/4" line I would imagine?
It would be worth a phone call to them to verify but I think it should be good to go.
