What size Carb. ???????
Which would be best for all around mud, hills, sand, trails and rocks
  • try to sort out the throttle body problems which Im having no luck with.
    Votes: 6 66.7%
  • 600 cfm single pump Holley
    Votes: 3 33.3%
  • 750 cfm single pump Holley
    Votes: 0 0.0%
  • 650 cfm double pumper Holley
    Votes: 0 0.0%
  • Total voters
    9
Supreme70
Detroit, Mi
Ok I have a stock 87 350 Chevy that i might be putting a towing cam in and add some headers come warm weather. My Question is what would be best for the motor. I have three 600 cfm single pump holley's, a 750 cfm single pump holley and a 650 cfm double pumper holley. They all need a rebuild so its a choice of which one, i plan on adding jet extentions to it for up hill climbs any other tricks as well??? The throttle body injection is giving problems that i cant seem to straighten out.
I would use one of the single 600 holley's, the others would probably be too big for stock and just harm fuel economy unnecessarily.
If i had TBI i sure wouldn't swap to a Holley. Even with the offroad mods it wont work half as well as TBI in the rough stuff.
That being said. If you are determined to use a holley. Use the 600 CFM single pumper. That is plenty of carb for your engine.
here is a good page that tells how to mod one so they will work acceptable offroadhttp://classicbroncos.com/carb_tricks.shtml
Why dont you post up your TBI problems over in the "Injection section"
We will do what we can to help you out.
choice # 1- try to fix the TBI even if it costs as much as a brand new carb you would be better off with FI then carbed. If there is no realistic way to fix it - 600 single pump , the others would be to much carb for the cubic inch and rpm range you will be in.
