what size gas tank do I have, 25 or 31?
pomai
Oahu, Hawaii
1988 Blazer.
I was under the impression that I had a 25 gallon gas tank, but when I do a search on a gas tank it comes up with a 31 gallon. lmc shows 25 gallon up to 87 and then 87 to 91 31 gallons?:dunno:
Thank you,
Ed
if I recall correctly
if top of tank to seam line is same as seam line to bottom of tank its the smaller .
if the seam to bottom of tank is more than top of tank measurement its the 31 gal .
Also, if you have a skid plate, minimal gap between plate and tank is 31 gallon. Large gap (over an 1") is the smaller tank.
LMC is wrong if they show a 31 gallon only starting in '87. 31 gallon AFAIK is far more common regardless of year, and I know 31 gallon was used as far back as '83 since I had them.
The '87-91 tanks (at least TBI) all had internal baffles, prior did not, that is why they show a year split in '87.
it appears to be the same. I think it is a 25 gallon.
thank you,
Ed
LMC shows 73 to 87 25 gallon and 73 to 91, 31 gallon. I was pretty sure I had a 25 gallon.
I was looking for a sending unit and my searches keeps coming up with a sending unit for a 31 gallon in my 88, I believe its a 25 gallon tank.
finally found a Doorman sending unit for 87-88 25 gallon tank.
thank you,
Ed
Never been on E? What's Hawaiian gas cost anyway?
funny you should say this .
took my plow truck stubby j.r. out the other day . got to the gas station and filled it up till it clicked .then went to next full dollar .
20 gal tank took 18.75 gal or so . :eek1: almost had to get out and push if I had gone any farther .
I've been so low that I actually ran out after I filled it.:haha: I was running off what was in the line. Filled it up and a mile down the road it died and I had to turn it over til it burped the air outta the line...:thumb:
