spearchucker
Good point. Sorry, but I work off of theory alone, real world situations aren't a factor in my book.The rheostat (I think thats the right term) that the float arm uses to "send" the fuel level to the gauge gets dead spots on it. Some sort of black corrosion from what I saw.
As mentioned, 0-90 ohms should be the sweep from either end of the gauge, but the problem is you can't see if there are dead spots without moving the float arm. It only takes a tiny amount of fuel slosh for the float arm to move, which influences the gauge.
If the slide on the rheostat is tarnished though I'd still try cleaning it first before dropping a couple bills for a new one.
