what size tank ?
riflerk20
Milton, NH
whats a good way, besides filling it up, to determine what size gas tank i have in my 87 k5? i need to replace the sending unit. thanks
RPO code from the sticker in the glove box. Is your sticker still there and readable?
i think you can go by shape too, different sizes are easy to tell by there shape i think...ive seen a thread on here somewhere...
Info from Stomper:
* Capacity: 31 Gallons/118 Liters
* Dimensions: 28-3/4 X 28-1/8 X 12-3/4 inches
* Small filler pipe - 1-1/4 inches inside diameter
* Depth of bottom half - 5-1/2 inches
* Capacity: 25 Gallons/95 Liters
* Dimensions: 28-3/4 X 28-1/8 X 10-3/4 inches
* Large filler pipe - 1-5/8 inches inside diameter
* Depth of bottom half - 3-1/2 inches
Absolute easiest way is if you have a stock tank skid plate.
If the tank nearly touches the skidplate (as in so close you can't see daylight through it), it's a 31 gallon. If there is a ~2" gap between tank and skidplate, it's the 25 gallon one.
The 25's are quite uncommon though, particularly later, and on gas rigs. Why do you have to replace the sender?
measurements, shape, and rpo all say its a 31 gal tank. great info and thanks for the help
