What size wheel
Highlander
Lakewood Colo
Ok I'm going to be putting a Dana 60 in the rear and will up grade to 3/4 ton Dana 44 8 lug hub's. Both have disk brakes and 4.56's the front has a ARB the rear is welded.
At the moment I'm 35 BFG's on 15x10 with a 2.5 lift with a 1in body. I plan on staying with 35's. But I would like some input about wheel size, I'm still looking for a tire that will last the best it can with a welded rearend. The truck is a daly driver Thanks Guys for the input.
<FORM METHOD=POST ACTION="http://coloradok5.com/forums/dopoll.php"><INPUT TYPE=HIDDEN NAME="pollname" VALUE="1043720617Highlander">
What wheel
<input type="radio" name="option" value="1" />15in
<input type="radio" name="option" value="2" />16in
<input type="radio" name="option" value="3" />17in
<INPUT TYPE=Submit NAME=Submit VALUE="Submit vote" class="buttons"></form>
Also I think I will go with steel wheels cause of the Mag Chloride (sp)
Eric
Well so far you guys and gals think it would out all right to run the 15in wheel with a 8 lug setup. Anybody else????
I run my d60/14 bolt with 15"-8lug wheel with about 4" bbackspacing. I like it.
-- Mike
If you want to you can run 15" wheels. I run 16.5's right now and i have a 14b and an 8 lug 44. you wouldn't need to grind or anything to stay 15's. When i did my swap i found out that the 44 8lug hd uses the same calipers and pads as my 10b front.
