desertrat67
Hawk Driver
Good noos.
Yep. Working perfectly.
Now where's my coolant going?
No, loose both. I have oil all over the bottom of the engine so nope, not going there.You're not loosing coolant and gaining oil, are you![]()
I'm kinda wondering as yesterday at lunch I drove over to Walmart (maybe 4 miles from work) and went inside for about 15 minutes. Came back (ironically enough with a jug of coolant and some oil) and discovered a 8" wide spot of fresh coolant under the d-side front. Friggin' upper radiator hose was leaking slightly.Leaky radiator like I have, but so slow that it evaporates before it hits the ground so you don't know it is leaking? Or Leaking crossover pipe draining it into the valley and again evaporation hiding the evidence? I have both of these problems.
I do have something in the valley but I suspect it's the IP leaking...![]()
