32 spline , 29 is dodgeInput shaft to the T-case. Tranny output is a male splined shaft, should be 29 splines for that application.
-- A
x232 spline , 29 is dodge
ThanksInput shaft to the T-case. Tranny output is a male splined shaft, should be 32 splines for that application. I can't count or remember shit. [EDIT]
-- A
Thanks32 spline , 29 is dodge
OK transfer case to get fixed.x2
and if that's broken it will need tear down to swap new in . so make sure to check all the rest of the parts and case . .
It is on the next level down where he has the boat. So no storage that would just be nuts. You should retire and start a tow company in district 5.So do you have the yellow truck at home or in a place that doesn't charge storage??
nope to BIG a chunk and its hardened metal . sterring box stuff much smaller and soft metal .Just a second guess, but could that be the steering column spline at the steering gear box?
So in other words you want to be like Timber Ridge.......Have a friend who owns a tow company that tells me to do the same and take over his so he can retire. No thanks. When I retire it will be no on call, no working nights, and definitely not full time job any more.
