What to do about wheels?
mollyman
west virginia
I'm putting a 14 blt in my sub and ditching the factory 12blt. It had 15x8 wheels on it but of course for 6 lug axles. I was wondering is there anything to keep in mind when getting a set of 8 lug wheels? I want to stick with the 15x8 size because I'm keeping the factory fronts on the 10blt (60 will not be possable till spring) also it is just the size I like. So can I just buy any set of 15x8 wheels (for truck use) with 8 lugs? Thanks for the help. Any advice on a good place to get a set would be great also.
You can get em. I got 15x8 8 lug wheels from discount tire. Summit also carries them.
These are the wheels I got.
Got mine from Summit for $26 each. IIRC I have 4.25" b/s, and fit over my 97s 14ff drums. I don't think they are too many choices for b/s goes, so might have to measure and see just what you would need.
Thanks for the info but I am still confused. When I look up wheels like at Summit they list bolt pattern size, what is that. And how do you measure backspacing? I don't want anything fancy, just some cheap steel wheels that will fit a stock (drum brake) 14blt on a 81 sub.
Also if I get a certain backspacing for the rear should I get the same in the front or will it be different?
The bolt pattern you want is 8x6.5. B/S is how far the wheel will stick out. If you have a 2.5" b/s wheel, all but the 2.5" will stick out past the body. Whereas a 5" wheel will tuck in more, if that makes any sense. You can get different b/s for front and rear, but easier just to get the same all around.
the BS measurement is from the rear face of the wheel to the mounting flange. IIRC factory 15x8 6 lug wheels are 3.5" BS.
I just installed 15x8's with 4" of BS on my 80. The rears will fit, no problem, but if you plan on running 15" wheels on a 3/4 or 1 ton front end, you will have to pull the grinder out and do some shaving. The calipers and backing plates need to be clearanced to run a 15" wheel. Figure 15-30 minutes of grinding per side with a 4", probably 1/2 that with a 7", but be careful. This is on a 3/4, on a Dana 60 you'll probably have to do a little more.
