Akjimmy907
Ok, need some help fellas................I'm going to build again but need to figure out which rig to build. I've got these two to play with.
Rig A. 81 1/2 Ton reg cab long bed with 6" lift, 350 motor, sm465 tranny, np208, body is rough.
Rig B. 1974 3/4 Ton Suburban, np 203, sm 465 tranny, Newer crate 350, body rough.
I have 3 sons who like to go wheelin with me, IF I built the Suburban I would Boat side it, Hummer cut the rear and attempt to bob the rear overhang a bit. I built a Burban before and hated the length when I got it off-road. Benefits to the Burban are........fit my family, crate 350 runs awesome, already has 14 bolt rear and I would only need to source a dana 60 for the front. The Long bed 1/2 ton would only need 1 ton axles and it would be a capable wheeler........so in short the 1/2 ton would need less work and it would be lighter and shorter to wheel BUT I'd have no room. The Burban is all stock and I would need to rob the 6" lift from the 1/2 ton, get a dana 60 and then do all the sheet metal "upgrades" ha ha. Oh yeah, the Burban is my plow truck so I'd have to wait till spring to start Mods and build up. I'm thinking go with the Burban, take OFF plow unit, put plow on 1/2 ton, put stock burban springs in 1/2 ton and have the half ton be the plow rig and Build, hack, frankenstein the Burban into a monstah!
