What to expect, when expecting?
Basically i'm just wanting to know if snow and detroits in both ends is a bad idea as I think it is. Even if the t-case is in 2wd but the front hubs are locked the truck will still want to go straight when the wheels are turned because of being locked at both ends. If the rear was open and the front locked I don't see any issues. Maybe i've got it all wrong. :dunno:
The only way to be 100% is come on up my way when the snow falls with the arb and compressor in hand. Go mash it in the snow for a while with the detroit up front. Pull it into my garage and install the ARB then re-test. After, im sure you will like the ARB more. And you could leave that detroit behind, and ill dispose of it in the proper method:whistle:
