Just as it says I know all the other dimensions just not the diameter of the u bolt. I would search but at work and away from my truck.
I'm pretty sure ALL the u-bolts on chevy trucks are 5/8" diameter.
You are correct, sir.I'm pretty sure ALL the u-bolts on chevy trucks are 5/8" diameter.
Yes 5/8 looks a lot better raped around the axle and 5/8 is the biggest bolt to fit in the plate on top the springs!
I bought a 78 chevy longbed on 40" with 4" spring lift and 4" blocks on all 4 coners. so i took the 4" block out and left the spring lift on. Oh and 40" are still on the truck.
So is that a no go on the 9/16.
never seen a single chevy truck come with anything bigger than 9/16" from the factory.
I'm pretty sure you'd have no trouble getting a 5/8" ubolt through a factory plate, if it was originally equipped with a 9/16" bolt. The factory left alot of tolerance.
Factory plates look kinda like a "W" shape in the rear and a casting in the front if memory serves.
One tons may have been bigger. Been a while but fairly certain, all the 1/2's and 3/4's i've been under were a 9/16".
On that note, I wouldn't hesitate to upgrade to 5/8".
