blazin_blazer
ok, so i finally got the deal worked out on the srw 86 k30, i went today and stripped it, i couldn't get the frame and he wanted to keep the flatbed, told me i could take anything else i wanted, so i got the already pulled 454,minus asseseries(needs rebuild??his words),radiator, motor mounts, (worn out, but i have lifetime replacement at autozone, so i figured i'd grab them and swap them for new), sm465/np205, bellhousing, linkages, crossmember, srw d60f, srw 14bff(some sort of load senseing brake thingy), the springs(had to beg to get the 56'' rears...question coming), shocks(look decent), driveshafts, the pedals, heater control, headlight switch, tilt steering column, hydroboost brakes, steering sector, heater blower motor, engine wiring harness, speedo cable, glovebox, ashtray, wipers, cowl....i'm sure i'm missing some little things i got also....wiper motor..., i basically stripped it bare today, all for $850, he plans on using a solid front axle, better cab(air) and front cap and 350/350, and making a wrecker w/ the flatbed by adding a boom and a winch and wanted the heavy frame and didn't want the "gas guzzling 454", my score
didn't know he meant i could have the motor
.(finally i can use the 366 crank and build my 427
, my fav gm motor)
so why did i title this thread like this
....ok, well, when i was pulling the rearend out w/springs attached, the front spring mount(rear springs) had a plate riveted to frame and the hanger that covered the bolt on the inside(looked factory).....i had to take a torch
and cut this plate out to drive the bolt out, why did they do this? did gm, not intend on any1 ever replacing or pulling the rear spring packs? seemed kinda dumb to me!?!??or did it serve a purpose(other than filling full of crud)???
pics to come....i'm planning on a build thread soon and since he kept the frame the swb cc is out
, so i guess i'm finally going to build my 69 blazer and use a 2nd gen frame b/c the original frame is fubar. i plan on selling all other projects and toys
to fund this 1.
, my fav gm motor)so why did i title this thread like this
and cut this plate out to drive the bolt out, why did they do this? did gm, not intend on any1 ever replacing or pulling the rear spring packs? seemed kinda dumb to me!?!??or did it serve a purpose(other than filling full of crud)???pics to come....i'm planning on a build thread soon and since he kept the frame the swb cc is out
to fund this 1.
..."sure!"
