Option D.
Get a manual.
Martin.
If its mounted ALOT higher than the transmission, and the cooler is big, and you want to eliminate trans fluid running back into the the transmission when the truck is not running... then C would be the way to mount it
Yeah It will Just be behind the grill.
Yours is behind the cab isn't it?
I like to run my trans cooler lines direct to the cooler and bypass the radiator because of the issue with trans cooler tub in the radiator leaking trans fluid into the coolant sometimes. I have mostly run my trans coolers in the A configuration you have in your diagram, but my 1-ton crew cab came from the factory with a trans cooler running in the B configuration, thus that is the way I run it.
I have run both the stock coolers and aftermarket external coolers and both have been fine. What's so wrong with going to the parts store and getting a stock radiator with cooler? I get it that if the truck is a "pile" the price of parts is a factor. You are about to spend $ on an aftermarket cooler, have to find a place to mount it and are asking questions about if it will work properly or not. If trans fluid is mixing with antifreeze then the radiator is basically toast all ready. Just go get the right part and an hour of wrenching later you have fixed the trans cooler and have prevented a radiator leak in the near future. Good luck with your truck.
Nothing wrong with buying new rad, good idea if this truck was going to be a DD. It is a truck we got for free because the trans slips and the brakes don`t work let alone the body is all rusted out and dented to shit. What we have found with it so far is that if the trans fluid is up to level it shifts fine.
We noticed the oil in the radiator when we where checking the freeze point of the antifreeze. Figured that must be the leak because the guy we got it from said it has a internal leak inside the trans that's why it slips. "Never heard that before" He obviously did not notice the oil in the antifreeze.
I gave the truck to my 15 year old son to build as a toy for around the farm. He and I have already fixed up a 01 Duramax that he bought when he was 12.
That truck is for DD duty when he get his licence. This truck is for cheep fun and experience for him to weld on.
I got 3 coolers sitting here to take my pick from for this truck, I never asked if it will work properly, just what way would be best to mount it. The way to mount it after reading all the posts seems to really not matter all that much.
Yes a new radiator would be best. But this old 77 is getting bypassed for free. If that fails to work is getting 465 swapped.![]()
Your transmission will likely go out in short order if coolant migrated into it via the defective cooler in the radiator..the clutch packs dont like anti-freeze,nor do bearings and O-rings..
