I know I can lift a t-350 and carry it hunched over but 203 kills me![]()
I changed my flex plate with a 400/203 combo, pretty heavy. Just unbolt the tranny from the motor as a tranny/tc combo, position the jack on the range box of the 203 because that is where the weight is centered, then just slide the combo back 6" and bolt up the flexplate, then rebolt the tranny when your done, dont pull it completly out unless something is wrong with it.
you need a jack under the motor as well, otherwise the dizzy will rest on the firewall when the motor leans back.
