So in my '68 lies an LS/4L65e. I had the cooling lines running into the radiator for the trans. It would see 220, 13 miles of stop and go traffic, by the time I get home from work. At times, even using the freeway, it would see these temps and occasionally hitting 225-228*.
I checked flow through the lines and that seemed fine. Plus, when I took the lines off everything was full of fluid.
So now I have about 30" of heat sink along my frame rail with the cooling line ONLY going to it. It doesn't heat up as fast but it is still seeing over 200*. The test run (and only run so far) saw 208* doing nothing but driving. (no pulling a grade, no constant racing at every light, etc) I felt the lines and they were hot and pulsing, plus the fins were hot, so it seems I have flow.
I don't know. This ain't right. By comparison, my "old" 700r4 takes a beating in the blazer all BB long and doesn't see over 190, with the majority at 180. WTF?
I guess I need to have the program checked.
BTW, the lockup IS working.
Whatcha think?
Whatcha think?
The truck definitely shifts different when its above 200
