what would this be worth to someone?
darkshadow
1 ton status
C-eh-N-eh-D-eh
my boss my be switching to a ford 9inch this winter for next season of drag raceing, just because.
the question is this, is anyone interested and what would you pay for:
12 bolt chevy rearend,5 stud, four link, raceing axles, 'c' clip elimanators, spool, I forget what gears,...... maybe maybe 4.10s (don't quote me) and just did all new barings.
it out of his gto witch is doing 10s
[ QUOTE ]
Think it'd fit under the rear of a 78 El Camino ???
[/ QUOTE ]
Anything will fit with a heat wrench. /forums/images/graemlins/thumb.gif
well it wont fit directly
you should measure width to see if it wqill work
youll have to torch and weld of course
so answer is technically no at this point
tape measure and such will help you alot
good luck
it's worth a grand,easy, if you add up the parts in it. depending on what width it is, it will fit under an elky with minor mods. if it's an original coilover axel, and the upper horns are still on it, all you need to do is weld on the later lower control arm mount's. It's not hard at all. Put a 12 bolt in a 82 elky, and a 78 malibu.
