Ok so now i have the ez wiring 21 kit in my posession....
I also have removed the rear wiring and under the hood. Next is in the cab.
now I am going to do a rewire mainly due to my fuseblock wires were worn and trashed..spliced and split and shorted....
The biggest thing I was not sure about for the ez kit was where to mount it.... I will have to remove the old fuse block and cover up the hole... mount this one up then drill a hole for the wires..... well neither of them really need to be done...
1. I found a hole big enough next to the fuse block... already punched out....not sure why but it is...
2. I noticed that the ez kit appears to use a GM factory style block... so I decided to take the plunge and cut mine out... yup no going back...
well guess what... the old piece fits on the new ez kit....
checkout the pics......
now this is promising.....
so:
1. I dont have to cover up the factory hole....
2. I can use the factory screw holes and bolt this on
3. I really dont have to use the punchout now...
so all of this and what is the question????
Would you use the factory plugs and tie the new wires in?????
here is the deal... I removed my wires that run from the tail lights all the way to the fuse plug.. .they are in great shape.....now the ez kit does provide wires that are long enough to go to the back... but there is nothing wrong with mine..... so if I used the factory block.... I could theoretically cut and crimp ends on the wires that need to feed the lights......
my under hood and in cab wires are in bad shape.....
my biggest fear is needing to take the truck apart.... I need to derive a system where stuff can be unplugged so I could take the front clip off.... or remove the rear bed (need to take tail lights out)
if I just wire it up the ez way you run wires and crimp everything together....
so what would you do? take that extra time and crimp in the factory harness back in but with new wires?
the painless kit for my truck with the oem harness was $560..... this one ran me $167... and all I would need are connectors.....
cmon ryoken.... which way would you do this??????
so:
