What year 10 Bolt
sunnyc123abc
SoCal
So my dad needs another 10 bolt for his 92 Blazer. The current one had a Gov Bomb and it finally blew. So what year axle can I use to replace it. Thanks
I'm assuming it's a full size? If so, you can use a 10 bolt rear from 88-98 (I believe) p-ups and Blazers. They have a wider track than the older 10 bolts. But then again, if you have a cut off wheel, grinder, and a welder, you can make just about anything fit! :D
Cool thanks. So is there any way of identifying the axle beside the body. How wide is the axle?
You can also find six lug 14b bolt semi floaters in that era for a direct bolt in as well , look on six lug K2500's .
Those are impossible to find, Id like to find one.
There are quite a few of the six lug semifloaters here. I you swap 10 for 10 then yes an 88-98 1/2 ton will work. If you go 10 to semifloat 14 then any 88-98 light duty 3/4 ton will work. The only possible need might be e-brake cables if they don't work from either axle. I just did the 10 to full float 14 bolt in my 95 tahoe, direct bolt in, then used adapters on the front.
Jeez, how many do you want??? Buddy is thinning out his j/y and took a sh!tload for scrap.....they are almost as plentyful as 60 rears..
