I just installed my disk conversion and I used rotors from a 75 3/4 ton. There are many years in this range that are interchangeable, but 75 is the year I use. I used the eldo calipers, but you can use the front calipers off a 75 3/4 ton, as well. For a disk bracket I ordered a set from one company and was really disappointed in the fit. I would have had to grind the bracket or the caliper. The hole for the mounting bolts was off a bit, too. I ordered DIY4X brackets and they fit perfectly and are better quality than the one I ordered first.....what a waste of money and time, but they are on and I'm happy with them. I had a hard time deciding between eldo and regular calipers, but decided to go for the eldos for the ebrake feature. Just don't have any experience with a yoke or transfer case mounted brake. Seem ok for a parking brake, but how do they work at 70 miles an hour??? Good Luck!
