what year did SBC Change bellhousing pattern?
69_chevy
Bedford
What year did the standard SBC change over to a different bellhousing pattern? like 60's to when? i think its 1996 but not sure??? what is the last year a th350, or th400 or sm 465 will bolt to using standard bellhousings? Please let me know if anyone has any clue?
ummm
chevy has never changed the bellhousing pattern on the small block cept for maybe the real early ones like pre 1960.
even the new genn III/genIV engines use the same pattern (minus one bolt)
so even like a 2000 vortec engine is the same?
So i can bolt a early70's sm 465 or th400 to a 2000 vortec engine?
yep. cant put the bolt that goes in the 2 oclock postion though. can the rest. that is if its a gen III/genIV if its the old 350 vortec will bolt up no problem
It will bolt up, but there might be a discreapancy with the flywheel though. IIRC the crank on the newer engines is in a different spot.
centerline to centerline is the same. distance from back of crank to transmission i have no idea.
guy on here has a 6.0 and 465 combo, so it cant be that hard.
