What year pick up cabs interchange
medicdave
Florida
Hey all, I know I've seen this on here before, but I searched and I can't find it tonight. I need a new cab for my 86 one ton project as the other had really bad hidden rust. Is it 81 or 83 to 87 that the cab mounts match up? Need to know with a quickness, have a line on a couple straight cabs....Dave
You can use any year cab. You just have to deal with the hood hinges
Just make sure you get the right steering column if you're going pre-85 to post-85, wipers moved from dash to column that year . . .
I thought they modified the frame in the early 80's to make room for the catalyitic converters. If this isn't the case, how far back will fit an 86's cab mounts. I've seen a slew of pretty cabs from the late 70's.
