What years did the 14BFF get factory discs?
mini_mull
Queen Creek, AZ
Just wondering what years the 14BFF got discs with the little e-brake drum assembly in the middle of the rotor. Also, what drivetrains did those 14BFF come with. I've been trying to search for it, but haven't found anything solid.
all the newer 10.5 AAM 14 bolts ( which is the same as the corprate 14bolt) use disks that is chevy and dodge, also the newer 11.5 14 bolt uses disks you may be able to get theses to work but im not 100% sure i would have to look at the prints for the two axles but i know the 11.5 uses a 2 pistion calpier in the rear.
