Whats a fair price.....
If its the manual clutch and complete with everything such as linkages, shifters, pedals, $500 tops.
If its the hydro clutch, more.
If you have the steering column and d-shafts to go with it, slightly more also.
Embarrasing, but I paid more than that. (Before I knew ANYTHING about what I was doing)...
But, I did get everything to do the swap including parts, linkages, pedals, column, bellhousing, clutch, driveshafts, tunnel cover, crossmembers, braces, brackets, wiring harness.....
Depending on where you are, supply and demand, etc... it's hard to say. But I'd go along with thatK30guy and say that just tranny/case/adapter should be under $500.
Agreed, supply and demand are the key words here for the best deal.
hell if you were closer i have one with shifter linkage and possible shafts with colom also i would sell for less than 500. but oh well. :doah: comes out of running truck.:eek1:
