Low87
Registered Member
Ongoing saga that started with replacing the fuel pump unit. Went to change the tstat while there, locked up bolts, had to remove the manifold, yada yada. When I had the dizzy out I noticed it was time to replace that, so I did.
Got everything back together today. Fuel is getting to the TBI, I know that for a fact because I forgot to tighten a fuel line.
No spark. Don't have electrical tools here and I'm alone. Pulled a plug and taped it to the cowl, looked at it while turning the key. Real safe I know.
When installing the dizzy there was only two ways to put it in (there's a "bar" across the middle, inside of the bottom). Thought I had it 180 off, so I pulled it and turned. Still nothing. Tried 2 different new ICMs. Quadruple checked all connections.
Any thoughts? Really getting pissed at this project. Borrowed car is reaching its limit. Wife is still understanding but I don't want to overdue that one either.
