so i need to put a 10 spline 465/205 set up into a 91 suburban that has a 465/208(241?) i don't want to get new driveshafts or clutch for it. so, what's involved in swapping the transfercase as well as the input shaft (that's the one that goes into the clutch... right?) if it's a big PITA to swap the input shaft, i'll do the new clutch - but i definitely will be needing to run the same transfercase. seem like all i gotta do for that, tho, is swap the adapter and the case.
i'm hoping to make this a one day event - is that doable? swapping trans out is no big deal.
thanks!
thanks!
it'll never see 4wd anyway. i just want it to be a simply day task.
