Whats my blazer worth?
stoney126
napa,CA
Not that I want to but no work is forcing me to sell. Im not sure what to ask for it so Help me out. Its a 84 cucv 6.2 turbo 400 208. I put a 14bFF in the rear with 4.10s and disc brakes. The front is a 8 lug 10 bolt with 4.10's with 1 year old warn lockouts and with new timpkin races and bearings. Bds 4 inch springs up front and a shackle flip in the rear. There is no rot on the truck. Also has a warn bumper gaurd on it too
The blazer was work in progress. It needs a new driveshaft because the one on there is to short. In turn I lowered the transfercase to help with vibration. You can drive on it but it will need to be taken care of. A axle seal on the rear needs to replaced. The brakes work really good but has the long travel pedal that I cant seem to get rid of. I put a 89-91 grill up front Turn signal and lights work except for running lights. I was going to do the relay but I have no money soooo. In the rear the PO cut a hole over the fuel sending unit. Which brings me to the sending unit, It doesnt work so great and the fuel tank leaks. There is no ebrake because of the Disc swap. I got power doors on there with no power:haha:( was going to take them off when It got hot. It leaks oil and the interior isnt great but you can sit in itand the seat belt works and so does the radio.
Btw It sits on 33's but the tires are poop, Ive been driving on them for awhile and they do hold air but for safety Id ditch em
So with all that being said what should I ask for it?
Sorry for the long post and Ill try to get more current pics
If the engine runs good and the trans runs good. I don't see why not.
besides them leaking they work great. 8 seconds on the gp's when its cold and it turns right over and it shifts fine.
