whats the best way to remove a steering box top cap
gmc4cw
west chester, Pa
do you remove the jam nut and spin the cap off the adjuster stud or screw the adjuster stud out of the cap and count turns? I need to swap my drilled and tapped top cap over to another box and don't want to mess up the backlash on the new box.
Last time I spun the cap off the stud but I am not sure if that was the right way to do it.
I removed the 4 bolts and the adjustment nut then spun the cap off. Reverse for installation. Worked ok for me but I did have to adjust the sector shaft a little.
Quick Hijack....I just put on a new steering box. Do I need to adjust it to my ride, or is it ready to go?
