All of the newer chevy engines use the 7 / 4 switched firing order these days. It helps smooth the engine out (put a new 8.1L beside a 7.4L, and you'll be amazed just how much smoother the 8.1L is), makes better use of the air intake harmonics that already exist, and exhibit a more balanced force on the crankshaft.
Becuase of the better harmonics, forces being distributed etc, you can expect to see a bit of a power increase (somewhere to the degree of 10 hp or so), but the bigger benefits has to do with the increase in the life of your engine's rotating assembly due to the decrease in stress put on the crankshaft.
