Front or rear? You will need a hub nut socket for the front and a bearing puller/slide hammer for the rears. If you are planning on just cleaning and repacking the fronts all you should need is the hub socket. If you want to replace the front bearings you will need a puller to remove the races from hub. A Haynes manual has the info and I am sure there are other books too.
