Wheel Recommendations
RJB44
Northern Virginia
Hi - I am interested in picking up some new wheels to replace the MT Classic IIs currently on the truck. My truck is two-tone black and white and I would like to get a set of all black wheels, however I would like the larger chrome center caps. I have a pair of unused MT closed end center caps, which are the ideal size that I would like for the black wheels. (4'). Some of the black wheels I have seen have smaller size center caps. So, can anyone suggest a decent wheel that can use the bigger caps. My classics are 15 x10 6X5.5 bolt pattern with 35 in Nitto Terra Grapplers. BTW.. I checked MT's website.
X2 on the soft 8s. Like 40 a piece from summit and my old center caps worked with them.
These are the ones I put on my burb. http://devinoroadconcepts.com/rwd_349.htm
thanks, i guess...lol...i doesnt look quite like that @ this moment...
picture.php
picture.php
picture.php
although i do have a set of 16's powdercoated black that i plan on puttin on there once i decided what tires i wanna run...then ill have these 15's blasted n coated black also...
i never had any because of the wheel size (15 x 8's), i was running 35x12.50x15's and the only problem i had was tires rubbed when flexed but i trim my fenders and am gonna put a lil more lift for the 36x14.50x15's i have on there now...i like em better than the 15 x 10's actually...jus my preference...gives u more sidewall to protect the rim, but then it does give u more sidewall to exposed to the elements when u air down...
