Wheel Spacers, 8 lug..Super Duty too!!
OffroadOverstock
Tulsa, OK
In addition to many other sizes...
Offroad Overstock now carries 2" thick SUPER DUTY spacers!! $139 a pair with lug nuts included.
GO HERE TO BUY NOW!
i have wanted to run bigger tires on mine but always wonder about what centers the outer rim to run true like on the stock setup?
the taper of the nuts.... unless you mean the ford hub-centric junk. I'd swap in a ff14b. :grin:
j
The same thing that centers your wheels...studs and tapered nuts.:wink1:
Just placed my order. Went with standard ground, seems like I really didn't want them that bad.:eek1: :wink1:
Yeh...UPS 3 day is a scam huh? When the little brown truck comes this afternoon you'll get tracking. THANKS!!
Just ordered up a set for myself. Patrick ensured me that he had bashed them hard, as have many others with zero problems. I can't wait for the BBT!
Yep, I only run 5 on 5.5" pattern w/ 42s and Helldorado and Coyote Ugly in Area BFE didn't even put the hurt on them. THANKS FOR THE ORDER!!
readymix said:
Anyone run these on stock HMMWV (non-recentered) rims on a SRW D60 and 14FF combo?
They are not thick enough for the deep offset rims... you would need closer to 4-5" spacers to make it work.
i was just looking at the 6 luggers. and was wondering. if one of the studs gets messed up can you take the spacer off and knock it out and replace it? or do you have to replace the whole thing?. just cant see the backs of them from the pics so i wasnt sure. thanks. -sam-
